SmartConnector Tutorial Extension Test Error
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector Tutorial Extension Test Error
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
ND7KR
Crewman ND7KR
Crewman
Posted: ‎2023-03-16 02:31 AM . Last Modified: ‎2023-03-16 02:33 AM
1321
As a new SmartConnector Extension Developer I follow Developer Guide Documentation.
However when I tried test (run and debug mode) I took
"OneTimeSetUp: System.IO.FileLoadException : Could not load file or assembly 'Mongoose.Common, Version=2.5.4.18, Culture=neutral, PublicKeyToken=223885051a9a1eff' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)" error.
I used .Net Framework 4.7.2 and SmartConnector Mongoose 2.5.5.3
Why i got this error? Any idea or solution will help me. Thank you.
Replies 4
MaximeLaudren
Lieutenant MaximeLaudren Lieutenant
Lieutenant
Posted: ‎2023-03-20 08:50 AM
The issue is that you probably does not have the same version of the DLL referenced in you application and the one available in your smartconnector installation folder.
Go in your smartconnector installation folder and locate the "Mongoose.Common.dll", then do right clic and properties, and check in the details what's the version of the DLL.
If the version does not match the one you refer in your application, then change you application so both version match.
Max
ND7KR
Crewman ND7KR
Crewman
Posted: ‎2023-03-22 03:37 AM
Thank you.
MaximeLaudren
Lieutenant
Posted: ‎2023-03-22 11:42 AM
If you can let us know what was the problem, if fixed, it would help other person as well.
Thanks!
ND7KR
Crewman ND7KR
Crewman
Posted: ‎2023-03-22 11:58 PM
I changed the application's packages as a version of 2.5.4.18 and than took the "Could not load file or assembly 'StructureMap, Version=3.1.4.0, Culture=neutral, PublicKeyToken=5cb6388d33b04e56' or one of its dependencies. The system cannot find the file specified." error. I added the referances StructureMap.dll from Smart Connector installation folder. Now its ok.
