PERMISSION_DENIED when acknowledge alarm
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • PERMISSION_DENIED when acknowledge alarm
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa197614_brid
sesa197614_brid Schneider Alumni (Retired)
Posted: ‎2017-06-07 05:50 PM
864
Lately when I developing an extension and I try to acknowledge the alarm events of SBO, it always tells PERMISSION_DENIED ,I am not sure any configuration incorrect.
For example when I try to acknowledge alarm event as:
{ "AlarmId": "02/Server 1/Test/OverTemp", "Acknowledgeable": 1, "OccurredOn": "2017-06-07T14:07:36Z", "LastTransitionedOn": "2017-06-08T00:07:08Z", "Message": "The room temp is too low", "Priority": 100, "State": 1, "Type": "GeneralAlarm", "Id": "/Server 1|/Server 1/Test/OverTemp|4c7f52bb-5450-41f9-9387-4a260242d023" },
And I recall the GUID of the alarm is the ID to be used for acknowledgement, then I use the Id=4c7f52bb-5450-41f9-9387-4a260242d023 to acknowledge this alarm, the response will be as:
{ "Message": "PERMISSION_DENIED" }
The SBO endpoint and credential is all correctly.
---Austen
sesa197614_brid
Posted: ‎2017-06-07 06:47 PM
I have figure it out, I should use Id="%2FServer%201%7C%2FServer%201%2FTest%2FOverTemp%7C11873d28-6e3c-4d03-8f8c-7f8d01e6e495" to acknowledge the alarm of my example.
Thanks.
sesa197614_brid
Thanks.
