How could I dynamically change the parameters of processor
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How could I dynamically change the parameters of processor
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa197614_brid
sesa197614_brid Schneider Alumni (Retired)
Posted: ‎2017-06-14 01:55 AM
3
782
How could I dynamically change the parameters of processor?
For example, for three parameters of a processor:
I'd like to design as:
1. When set Using CSVPointList as True, the EWSContainerID will be blank and gray out or even invisible.
2. When set Using CSVPointList as False, the CSVFilePath will be blank and gray out or even invisible.
Is there a way for me do this?
-Austen Yin
sesa180908_brid
Commander
Posted: ‎2017-06-14 05:52 AM
Austen,
This type of functionality is not currently supported for configurations.
JeffBowman
Sisko
Posted: ‎2017-06-14 06:23 AM
747
To expand upon what Mark said,
The type of functionality you are looking for is custom UI functionality, while we do have an enhancement request in the backlog for this, it is not currently in development.
As a workaround, may I suggest you implement custom 'validation' on the processor (see developers guide). That way the processor won't run with an invalid configuration. And the user will be told what is wrong when they click the 'validate' button during configuration. It is not the most pretty way to get this functionality, but at least you won't have configurations running that are not valid.
-Jeff
sesa197614_brid
Posted: ‎2017-06-14 06:19 PM
Thanks, for functionality, it will be OK to be with fixed UI, I seek for custom UI to try to make it more clear which won't confuse user.
Instead,  now I add some ToolTip to those parameters to guide user.
-Austen
