Need help with schneider plc
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Need help with schneider plc
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2022-04-06 01:11 AM
1297
Hello I'm using schneider plc TM200CE24U I'm communication it with Ethernet. The data is coming via modbus tcp/IP. Can someone please help me to program it. I mean I don't know how my modbus data is converted into input. My program is very simple I have one modbus address and when it turn zero to 1 my output should start. And when it again it turn to zero it should turn off output. Can someone please help me with it. Thank you.
MaximeLaudren
Lieutenant MaximeLaudren Lieutenant
Lieutenant
Posted: ‎2022-05-20 11:20 AM . Last Modified: ‎2022-10-19 12:51 AM
Hello Metan,
This forum is related to question about the smartconnector application.
For further question, I would advice to to check in the PLC forum: https://community.se.com/t5/Industrial-Automation/ct-p/industry_automation_control
To program you PLC you will need this application: EcoStruxure Machine Expert-Basic (Version V1.2)
https://www.se.com/in/en/product-range/62882-modicon-easy-m200/?parent-subcategory-id=3910&filter=bu...
Max
