Error code: -96
Error message: License server machine is down or not responding.
How to solve this problem?
@Temirlan I would suggest you check the License Administrator for the ES. The ES should have its own License Server and running under Windows Service.
Hello @Temirlan ,
Have you been able to solve the issue with the article Craig shared?
If so, please mark his reply as solution.
Otherwise, we will need more information about the issue, can you share ES logs, and what's the license status in License Administrator.
