DateTime Format For GET/TrendSamples
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • DateTime Format For GET/TrendSamples
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
petri_greenwave
Lt. Commander | EcoXpert Master petri_greenwave Lt. Commander | EcoXpert Master
Posted: ‎2017-05-09 02:51 AM
1254
Hi All,
I am struggling a bit to get a DateTime filter going when using GET/TrendSamples.
What should the format be for this? I have tried a bunch of different formats however it keeps returning all the latest entries.
Parameter
Description
Parameter Type
Data Type
alarmId
Return only
AlarmEvent for the referenced Alarm.
Query
String
trendId
The
Id of the Trend which TrendSample are to be returned for. This parameter is not optional.
Query
String
state
Return only
TrendSample with this State value.
Query
Enumeration
(See
Table 1)
sampleOnOrAfter
Return only
TrendSample with SampleDate which is on or after this value.
Query
DateTime
sampledBefore
Return only
TrendSample with SampleDate which is before this value.
Query
DateTime
orderBy
TrendSample
will be returned in this order. SampleDateAscending by default.
Query
Enumeration
SampleDateAscending=0
SampleDateDescending=1
take
Number of
TrendSample that should be returned. 200 by default.
Query
Integer
skip
Number of
TrendSample that should be skipped before items are returned. 0 by default.
Query
Integer
  • get trendsamples
sesa180908_brid
Commander
Posted: ‎2017-05-09 06:14 AM
1227
Any valid date format will work however, if your values do not include time zone offset or are not in UTC format, then the resulting predicate may not be what you intended.
Also, sampledOnOrAfter and sampledBefore can be used separately or in tandem.  So each side of the following expression may be omitted if the supplied value is null.
TrendSample.SampleDate>= sampledOnOrAfter && TrendSample.SampleDate< sampledBefore
Some sample requests would be helpful in determining where the issue may be.  If you are using the SOAP provider, you should enable "Ews Consume" filtering (Debug level) and you will see how your REST calls are translated into an EWS SOAP request.
petri_greenwave
Posted: ‎2017-05-09 10:50 PM
1227
Hi Mark,
Ok Using the time format 2017-05-09T22:00:07Z did the trick. However I have a concern on how Smart Connector is handling the timestamps on the samples.
In South Africa We are GMT+2. When I run the GET/TrendSamples request it reduces the actual timestamp by 2 hours and what makes it worse is if I have a midnight sample on 2017-05-10, it incorrectly gives me a timestamp of 2017-05-09 22:00PM.
Of course it is using UTC but there must be a way to get around this:
sesa180908_brid
Commander
Posted: ‎2017-05-10 06:36 AM
Petri,
All values returned by the REST Gateway should be in UTC.  With the SoapEwsRestProvider, SmartConnector is passing the values through from the server since EWS mandates that the values returned are in UTC.
Before we can determine if this might be a serialization issue in the REST layer, we need to see what SBO is returning over SOAP.
Do you have any log captures with that information?  If you enable "Ews Consume" logging filter at Debug level you will see the SOAP request/response pairs.  If the value there is correct, but the value returned over REST is not, then we may have a serialization issue.
