Ask Me About Webinar: Data Center Assets - Modeling, Cooling, and CFD Simulation Join our 30-minute expert session on July 10, 2025 (9:00 AM & 5:00 PM CET), to explore Digital Twins, cooling simulations, and IT infrastructure modeling. Learn how to boost resiliency and plan power capacity effectively.Register now to secure your spot!
Customer cannot login localhost:8082
SmartConnector Forum
Send InviteCancel
2023-09-1502:42 AM
Customer Installed SmartConnector on their server and the portalpage does not load. He said that the service is in running state, but the login page do not respond.
2023-09-14 16:30:03.7451,Error,Service,<no principal>,Unable to load DLL 'SE.WorkStation.Licensing.LMClient32.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at SE.WorkStation.Licensing.LMClient.Api.Managers.NativeMethods.License32.OpenSession()
at SE.WorkStation.Licensing.LMClient.Api.Managers.LicenseSystem.OpenSession()
at SE.WorkStation.Licensing.LMClient.Api.Services.LicenseService.SessionHandle()
at SE.WorkStation.Licensing.LMClient.Api.Services.LicenseService.Checkout(String feature, String version, Int32 quantity)
at Mongoose.Service.Licensing.LicenseEnforcer.HasValidFlexeraLicense()
But are those only because of the missing license? The license cannot be loaded if the portalpage do not respond...
