Configure Azure AD for IT Expert SAML SSO
Single Sign On (SSO)
How to configure SAML Single Sign On (SSO) in EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • Single Sign On (SSO)
  • Configure Azure AD for IT Expert SAML SSO
  • Mark as Read
  • EcoStruxure IT forum
EcoStruxure IT Support
Request Support
Back to Single Sign On (SSO)
  • Mark as Read
Picard EcoStruxureIT
‎2021-09-23 07:42 AM
Last Updated: Sisko JLehr Sisko ‎2025-06-04 04:41 AM
Instructions for how to Configure SAML single sign on (SSO) in IT Expert
Also see IT Expert permissions
In Azure:
Add a new enterprise application.
Go to Single sign-on, and then select SAML.
Enter the Basic SAML Configuration details in Azure as shown in IT Expert on the Administration > More... > SSO page:
Click Edit in the User Attributes & Claims section.
Note: Group configuration is not applicable for partners.
Click Add new claim.
In the Name field, enter group (use lower case only).
Expand Claim conditions.
Add a claim condition for Any user type.
Select the groups that should have user level permissions to IT Expert.
Under Source, select Attribute.
Under Value, enter <your user group name> (use lower case only).
Add another claim condition.
Select the groups that should have Administrator level permissions in IT Expert.
Under Value, enter <your administrator group name>.
Click Save.
The UI should look like this. '
Comments
Conchi
Ensign Conchi Ensign
Ensign
  • Mark as Read
‎2024-03-07 04:23 AM
This information is very interesting. I'm new working with Azure platform.
Please, What kind of enterprise application did you created in Azure?
Thank you.
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2024-03-20 06:48 PM
Hi @Conchi,
This article is about how customers can configure Azure so their users can use SSO to log in to EcoStruxure IT Expert.
Conchi
Ensign
  • Mark as Read
‎2024-03-21 01:45 AM
Hi @JLehr , thanks for your answer. Finally, I could configure it properly.
Best Regards
GrantThorntonAus
Ensign GrantThorntonAus
Ensign
  • Mark as Read
‎2025-05-22 05:50 PM
You dont mention using 'lowercase' for the 'Administrators' group, and then in your screenshot you even show it with a capital 'A'. This matches the existing default Administrators group in ITE. But it doesnt work. Misleading and time wasting unfortunately.
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2025-05-27 01:17 PM
Hi @GrantThorntonAus ,
I'll investigate and will make corrections as needed.
Thanks for helping us improve!
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2025-05-29 07:51 AM
Engineering has confirmed that upper case A is the proper guidance.
It's possible that some other underlying issue might have caused you problems, but that's hard to tell without seeing your configuration.
You may want to contact support for assistance if you have further concerns.
