Configure SAML single sign on (SSO) in IT Expert
Single Sign On (SSO)
How to configure SAML Single Sign On (SSO) in EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • Single Sign On (SSO)
  • Configure SAML single sign on (SSO) in IT Expert
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Single Sign On (SSO)
  • Mark as Read
Picard EcoStruxureIT
‎2021-06-23 11:39 PM
Last Updated: Sisko JLehr Sisko ‎2025-02-18 08:46 AM
Administrator users and partners can configure SAML 2.0 single sign on in the Administration > More > SSO option in IT Expert. Any identity provider (IdP) that supports the SAML protocol is supported.
An EcoStruxure IT Expert subscription is required.
Once you configure SSO, all users with an email address on one of the domains you specify must use your identity provider to log in to IT Expert.
You can still use the IT Expert Administration > Users option to invite and manage users from email domains not using the domains you specify for SSO.
If your SSO certificate expires, you must reset your SSO configuration.
It is strongly recommended that at least one Administrator user who does not require SSO to log in is configured in IT Expert Administration > Users.
If you subscribe devices to EcoStruxure Asset Advisor and configure SSO, you must also configure your organization's users on the Administration > Users tab. Otherwise, the Schneider Electric Service Bureau cannot contact the individuals responsible in case of an incident.
In this article
  • Configure your identity provider
  • Supported SAML attributes
  • Configure SSO in IT Expert
    • 1. Enter SAML details
    • 2. Test SAML configuration
    • 3. Verify domain ownership
    • Enable Identity Provider (idP) Initiated SSO login
  • Update your SAML SSO certificate or sign-in URL
  • Reset SSO configuration
Azure users also see Configure Azure AD for IT Expert SAML SSO
Before you configure SSO in IT Expert, use the Identity Provider details on the Administration > More > SSO page to configure the integration with IT Expert in your identity provider's user interface.
Refer to your identity provider's documentation for more information.
  1. Log in to IT Expert and go to Administration > More > SSO.
  2. Copy and paste the SAML Assertion Consumer Service (ACS) URL and the SP Entity ID in the appropriate fields. These values are specific to your account.
    Note: The SP Metadata URL will be displayed in step 2 of the IT Expert configuration. Some identity providers require it.
  3. IT Expert requires that you configure your identity provider to send these three SAML attributes:
        • "name": How user names are displayed
        • "email": User email address
        • "groups": The groups your IT Expert users are members of
          Note: Groups configuration is not applicable for partners.
If your identity provider does not support adding the SAML attributes above, see the full list of supported SAML attributes below to use as alternatives.
You can create groups in both your identity provider and IT Expert; group names must match exactly in both. You can assign access permission for each group on the IT Expert Administration > Groups tab. See IT Expert permissions
Note: IT Expert contains two groups by default, Administrators and Users.
Users you want to have Administrator rights in ITE must have a group SAML attribute with the value "Administrators."  Users who should have regular user rights in ITE must have a group SAML attribute with the value "Users." Users without a group SAML attribute will not have access to ITE.
Consult the documentation for your identity provider to learn about adding SAML attributes.
Note: Every time a user logs in using SSO, the identity provider sends EcoStruxure IT a list of the groups the user belongs to. If any changes to group assignments are needed, you make the changes in your identity provider, not in IT Expert.
EcoStruxure IT supports these attributes, if, for example, your identity provider only supports InCommon Federation Attributes, or other standard attributes:
SAML attribute
Description
name
Display name of the user
displayname
urn:oid:2.16.840.1.113730.3.1.241
http://schemas.microsoft.com/identity/claims/displayname
http://schemas.xmlsoap.org/ws/2005/05/identity/claims/name
email
E-mail address of the user
urn:oid:0.9.2342.19200300.100.1.3
http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress
phone
Phone number of the user
phoneNumber
telephoneNumber
urn:oid:2.5.4.20
urn:oid:0.9.2342.19200300.100.1.20
urn:oid:0.9.2342.19200300.100.1.41
http://schemas.xmlsoap.org/ws/2005/05/identity/claims/mobilephone
group
List of groups the user is a member of
groups
urn:oid:2.16.840.1.113719.1.1.4.1.25
http://schemas.xmlsoap.org/claims/Group
Your identity provider will provide the information needed to configure SSO in IT Expert.
Return to IT Expert Administration > More... > SSO.
  1. Copy the SAML SSO sign-in URL from your identity provider into the SAML SSO sign-in URL field.
    In Azure, this is the User access URL under Properties.
    The URL must start with https://
  2. Upload your SAML SSO certificate or paste it into the text field. The certificate must be x.509 in *.PEM or *.CER format.
    The certificate must start with:
     ‘-----BEGIN CERTIFICATE-----’
    and end with:
    ‘-----END CERTIFICATE-----’
    Make sure there are no blank lines before or afterThe certificate expiration date is automatically extracted from the valid certificate and cannot be edited.
  3. Specify your Sign-in email domain(s). For example, if user email addresses are user@mydomain.com, enter mydomain.com in the field.
    Separate multiple domains with a comma, or use the Enter or Tab keys.
    Note: All users with an email address on one of the domains you specify must use your identity provider to log in to IT Expert.
The Continue button is enabled when all the field are populated and valid.
Verify that your SAML connection is configured properly.
  1. Open a different browser or an incognito window.
  2. Go to https://ecostruxureit.com and click Log in. Choose Customer.
  3. Enter the test email address shown in ITE.
    The password field will disappear, and the login for your identity provider will be displayed.
  4. Log in to EcoStruxure IT as Administrator.
  5. Return to SSO configuration in ITE. If the test login was successful, click Verify.
    If the test login was not successful, the SAML configuration is incorrect. Click Not working? Start again.
IMPORTANT: You must successfully test your connection to enable SSO for your email domains.
You must verify that you own the domains you specified in the SAML details. There are three ways to verify ownership: DNS TXT, HTML file, or HTML META. The verification method you choose depends on your domain's web host.
Contact your Customer Success Manager for help verifying your domain ownership if needed.
DNS
  1. Go to the home page of your domain and create a DNS TXT record.
  2. Copy the TXT content displayed in ITE starting with ecostruxure-it-verification=
  3. Return to ITE and click Verify. A checkmark icon ITE SAML domain verified icon.png appears next to verified domains.
HTML file
  1. Create the file ecostruxure-it-verification.html using the contents diplayed in ITE, and upload it to your domain's website.
    Your website must be publicly available at the naked domain, with no www or any other subdomain prefix in its URL. Example: https://randomdomain.dk/ecostruxure-it-verification.html
  2. Return to ITE and click Verify.
HTML META
  1. Add the meta tag displayed in ITE to the <head> section of your website's home page.
Repeat step 3 to verify all the domains you specified.
Once you have verified all your domains, your SSO configuration is complete. You can return to the SSO page to add and verify additional domains as necessary.
You can remove unverified domains at any time. You can remove verified domains as long as at least one verified domain is configured.
Enable Identity Provider (IdP) Initiated SSO login
Check to allow users to log in to IT Expert from the login page for your organization's identity provider.
Note: IT Expert uses OIDC as a response protocol.
See Identity Provider (IdP) initiated SSO risks and considerations
Edit configuration
Click Edit configuration to update your SAML SSO sign-in URL or SAML SSO certificate.
Note: Edit mode is available only when there is at least one Administrator user configured in IT Expert who does not required SSO to log in.
You can jump between configuration steps when in edit mode.
Click Yes to continue.
Update your SAML SSO sign-in URL and SAML SSO certificate as needed.
The expiration date is extracted from the certificate and cannot be edited.
Click Continue.
Click Cancel Edit if you decide not to make changes at this time or you make a mistake.
Test your SAML configuration (see step 2 above) and then verify your domain (see step 3 above) to enable SAML SSO settings.
Resetting your SSO configuration completely removes all SSO settings in IT Expert.
You must start again at step 1 to reconfigure SSO, including reconfiguring SSO when your SSO certificate has expired.
The URLs and verification files from any previous ITE SSO configuration cannot be reused.
When you reset your SSO configuration, users who are required to use SSO to log in to ITE will no longer have access unless they also have IT Expert user accounts listed in Administration > Users.
100% helpful (1/1)
Comments
maxstr
maxstr
Cadet
  • Mark as Read
‎2024-11-26 11:24 AM
When adding the certificate, I downloaded the PEM file directly from Azure, but it kept saying invalid certificate. I figured out I had to delete the last line for it to be accepted. For example, after the part that says "-----END CERTIFICATE-----", there was a blank line below it that I needed to delete.
Schneider should automatically trim empty lines because those certificates have a blank line by default
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2024-12-02 08:47 AM
Hi @maxstr,
Thanks for the feedback. I'll pass it along.
You can provide feedback directly in the IT Expert application, too. Click the Help icon (?) in the upper right corner and then click Feedback.
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2024-12-03 06:22 AM
Hi @maxstr,
Thanks again for pointing out the spacing issue in the certificate. Engineering will address it shortly.
Best,
Jackie
Kenny_Roach
Kenny_Roach
Cadet
  • Mark as Read
‎2025-05-29 12:25 PM
After adding the DNS TXT records and successfully verifying the domains, can the DNS TXT files be deleted?
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2025-06-04 05:39 AM
Hi @Kenny_Roach,
Deleting the DNS TXT record won't affect SSO logins once you have verified the domain. If you delete it and you need to verify the domain again in the future, you'll have to add that TXT entry again into your DNS.
Vinay_G
Vinay_G Cadet
Cadet
  • Mark as Read
‎2025-08-27 07:09 PM
If a new user joins the organization and requires access to IT Expert, where should the admin add the user?
The admin has already sent an invitation to the new user, but they are encountering the following error. Could you please advise on the steps needed to resolve this issue?
Admiral
  • Mark as Read
‎2025-09-03 10:47 AM
@Vinay_G,  The user is missing a configuration item (likely group association) within the SSO provider configuration.  The following will hopefully help you resolve this issue:
  • https://learn.microsoft.com/en-us/answers/questions/1314525/how-to-fix-error-aadsts50105-error-appea...
  • https://learn.microsoft.com/en-us/entra/identity/enterprise-apps/assign-user-or-group-access-portal?...
