Missing an important Push Button Dimmer Toggle Mode feature
  • Missing an important Push Button Dimmer Toggle Mode feature
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
dannyvdpoel
Crewman dannyvdpoel
Crewman
Posted: ‎2024-11-23 07:50 AM
658
I have a Push Button Dimmer with the On & Off buttons with dimmer side by side and two additional Moment buttons underneath.
I would like to I would like to set the default dimmer value to a fixed value less than 100%, so that every time I press the On button it will light with this pre-set dimming percentage. Today this is not possible.
The Toggle Mode setting options I have are:
  • 100% or
  • Last Level
A third option should be added to set default dimmer level to a value less than 100% !!
Here is the issue:
I find the 100% level too bright for the Lamp used where it is placed + plus I like to be eco friendly and save some power. I can of course set the Toggle Mode to Last level and set the Dimmer % to my preferred value (e.g. 50%). However if I use on of the Moments Buttons to control the same Lamp and use a different Dimmer %  (e.g. 25%) for this Button, then when the Lamp is turned off, it will become the 25% Dimmer value that becomes the Last Level, and next time I turn on the Lamp it will turn on at 25%.
I have tried to set the Dimmer range to max at my 50% Level, but if Toggle Mode is set to 100%, it will overrule the Dimmer range setting.
Can we please get this feature added to Toggle Mode or have anyone figured out a good way of overcoming this issue? Help me please 🙂
  • Apps
David_SE
Admiral
Posted: ‎2025-05-20 05:12 AM
Hi @dannyvdpoel ,
Thanks for your post, as it is an old one and new system releases were published, i closed that post.
Please open a new one if you consider that behaviour can be a good idea of improvement.
BR
David
David_SE
Admiral
Hi @dannyvdpoel ,
BR
David
