Just bought starter kit and so far looks good apart from Edit Schedules
  • Just bought starter kit and so far looks good apart from Edit Schedules
David_SE
Captain David_SE Captain
144
Alfred_SE
24
Maude.wiser.
22
emjga
emjga
Cadet
Posted: ‎2024-01-04 07:23 AM
634
Using my Android phone Galaxy S10e
I can select and Edit Schedule
Edit Event
Temperature :I can change
When : I can change the start time
However I can see how to set the end time.
Am I doing something relay odd (properly)
App version 6.6.0
  • Apps
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: ‎2024-04-03 07:01 AM
the end time is determined by the start time of the next event. So unless your house is really cold....
the following would give you heating on at 0900 off at 1100 back on at 1400 and off at 2300.
it does take a little bit of getting your head around but once you've done it a couple of times it becomes obvious.
Start 09:00 19°
Start 11:00 13°
Start 14:00 20°
Start 23:00 13°
Regards Brian
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
BrianT58
Lieutenant BrianT58
Lieutenant
Start 09:00 19°
Start 11:00 13°
Start 14:00 20°
Start 23:00 13°
Regards Brian
Regards Brian
