Humidity data in Wiser app (UK)
  • Humidity data in Wiser app (UK)
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
Posted: ‎2022-02-14 01:58 PM
7
4088
Been running wiser for my home for the last month, working very nicely.
I have two roomstats, but display humidity data on screen. Can I see this data alongside temperature in the Insights page of the app?
  • Apps
  • New feature request
  • Wiser - UK
Alfred_SE
Posted: ‎2022-02-16 07:51 AM
4057
Thanks for reaching out.
We don’t have this feature in the app at the moment. It is only available on the screen.
Your feedback will be taken into consideration and will be raised to the development team.
Alfred Francis
Replies 7
Alfred_SE
4058
Alfred Francis
Endstat
Endstat
Cadet
Posted: ‎2022-11-25 07:36 AM
In response to Alfred_SE
I would like to see this feature too.
Darcey
Ensign Darcey
Ensign
Posted: ‎2022-11-30 05:05 AM
Hi Alfred
I'm also interested in the humidity readout provided by the roomstat.
I bought a dehumidifier that has no display, just a target humidity selector. An humidity sensor I have shows the humidity levels dropping roughly inline with the settings of the dehumidifier unit. The schneider roomstat however does not show the same degree of change.
I have the roomstat stuck to the wall with a blob of bluetak! Could I be inadvertently blocking the sensor?
HussaynV
HussaynV
Cadet
Posted: ‎2023-11-07 03:24 PM
Hi
Being able to view and log the humidity over time from the room thermostats like you can with temperature would be a great feature.
Its been over 18 months since you took this on as feedback.
Is the ability to view and log humidity in the app a technical limitation of the wiser ecosystem or is this something that technically you can develop, but either choosing to limit this or yet to be fully developed?
Basically is it coming any time soon?
andrewf
Crewman andrewf
Crewman
Posted: ‎2024-02-10 02:56 AM
I also would like to be able to access the humidity data in the app (and via other home automation mechanisms that integrate with Wiser). Having to buy a separate humidity sensor, to do this when the Wiser thermostats already are measuring humidity, seems a bit silly.  Supporting humidity data would also make the Wiser thermostats a more important part of a smart home as opposed to a one-function device only useful for the Wiser system e.g. the humidity data could be used to control other things like fans
robertwigley
Crewman robertwigley
Crewman
Posted: ‎2024-02-15 08:47 AM
2863
The humidity data (along with a lot of other extended features) can be accessed if you use Wiser with Home Assistant.
andrewf
Crewman andrewf
Crewman
Posted: ‎2024-02-19 05:10 AM
In response to robertwigley
Yes I just discovered it was actually available in Home Assistant and I've just started working out how to take the plunge and setup HA.
It would still be good if the humidity data was more widely available (like the Wiser app, Google Home etc) e.g. for people not ready (or willing) to go down the Home Assistant route
Andrew
