Scadapack E-configurator CLR20r3 Event log
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Scadapack E-configurator CLR20r3 Event log
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
SCADAPack 300E
Gabz
Crewman Gabz
Crewman
Posted: ‎2021-06-21 07:37 PM
2222
With Windows 10 E-configurator doesn't launch
it creates a event in in the windows event log CLR20r3
googling indicates some sort of .Net dependency error but reinstalling .net doesn't appear to have fixed it
Attached is the full error report.
I had a similar problem that e-configurator wouldn't launch if you had at any point installed a Sierra wireless 4G card but this appears to be a different issue.
  • RTU
  • Telemetry
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-06-21 08:46 PM
2218
What versions of the .NET Framework do you currently have installed?
It looks like it's using mscorlib 2.0.0.0, which I think is from .NET Framework v2->3.5
I believe in .NET Framework 4 it was reversioned to be mscorlib 4.0.0.0... and I would have almost thought that a recent version of E Configurator would use a more recent version of .NET Framework (i.e. v4+)
For issues like this, where a crash occurs, you should raise a case with your local Tech Support also.  It's important that it gets logged in the Schneider system.  This community forum doesn't have that happen.. we're mostly end users / system integrators here.
Has this machine had other versions of E Configurator working on it?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Gabz
Crewman Gabz
Crewman
Posted: ‎2021-06-21 09:21 PM
In response to BevanWeiss
It got raised with SE support and the follow advice was given
Check Prerequisite Microsoft Installers for additional information.
· Microsoft .NET Framework 4.5.1 offline installer
· Microsoft Visual Studio 2013 Isolated Shell
· Microsoft Visual C++ 2013 Redistributable Package (vcredist_x86.exe)
· KB VS12-KB3107629.exe
Reinstall .NET Framework  2.0
The final advice was run it in a VM which we did get to work.
Just hoping someone else had a solution which wasn't reinstall windows 10.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
