SCADAPack 5407 replacement
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • SCADAPack 5407 replacement
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Abanoub
Ensign Abanoub Ensign
Ensign
Posted: ‎2021-12-20 08:20 AM . Last Modified: ‎2021-12-20 08:21 AM
3138
Hi community,
I am searching for a direct replacement for SCADAPack DO Expansion module 5407.
Here are the specs of 5407 we have to comply..
Operate time = 5ms typical 10ms max
Release time = 2ms typical 10ms max
Bounce Time = 3ms typical
Max current/ channel = 2A.
Appreciate your support.
  • RTU
  • 5407
  • digital output
  • SCADAPack
Joel_Weder
Captain
Posted: ‎2021-12-20 09:12 AM
3
3129
The most similar replacement module for the 5407 8-point relay output module is the 5415, which is a 12-point relay output module. However, the 5415 does not match the specifications you have listed, with 20ms typical Operate time and 25ms typical Release time.
For very fast Operate and Release time you may want to consider a solid-state (FET) output module rather than a relay module. They switch so quickly that these specs are not even noted. The 5409 can handle 2 amps continuous on each output, for example.  You did not mention the voltage being switched - the 5409 is typically for 12 or 24 volt systems.
Joel Weder
Remote Operations Specialist
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-12-21 02:16 PM
In response to Joel_Weder
2
3120
Important to note that FET outputs can only handle DC voltages/currents.  Which is generally the most common anyway.
However, it's still not uncommon to see 12VAC / 24VAC field actuators in use, which would require either a dry contact relay style output, or an alternative solid state relay (thyristor driven, not FET).
My suggestion would be to utilise the 5409 with a 24VDC supply, and then if AC switching is required (or anything else requiring true dry contacts) to utilise some slimline terminal relays (these are available from a large number of vendors, ABB, Finder, Phoenix Contact, Allen-Bradley, etc, etc.. heck probably even Schneider).
The Finder 38 series relays are in the <10ms range for the electromechanical type, the SSR type are generally sub-ms
https://www.finder-relais.net/en/finder-relays-series-38.pdf
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain MartinChartrand Captain
Captain
Posted: ‎2021-12-22 05:09 AM
In response to Abanoub
Just a minor correction to the conversation, the 5409 is still available and can be ordered using part number TBUX297117. It was not on the list of 5000-Series I/O expansion modules that were retired in 2020 or 2021.
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Posted: ‎2021-12-23 06:08 AM
I can't get you name of the components easily but I can provide the specifications from the user manuals.
Please note that the 5415 comes in two versions: Dry Contact and Solid State relays. I have included their specs here as well as for the obsolete 5407.
5415 Dry Contact Relay Version
Contact rating:
  • 3 A, 30 Vdc or 250 Vac (Resistive)
  • 1000 Vac between open contacts
  • 12 A maximum per common
Switching Capacity:
  • 5 A, 30 Vdc (150 W Resistive)
  • 5 A X 250 Vac (1250 VA Resistive)
Service Life:
  • 2 X 107 mechanical
  • 1 X 105 at 5 A, 30 Vdc or 250 Vac
Bounce Time: 1 ms typical
5415 DC Solid State Relay Version
Load voltage: 60 Vdc maximum
Load current:
  • 3 A continuous maximum at 50ºC (122ºF) ambient
  • 2 A continuous maximum at 70ºC (158ºF) ambient
  • 9 A peak, 100ms
  • UL508 rated 2 A at 50 ºC and 1.33A at 70 ºC (158 ºF.)
On resistance: 0.09 ohms
Off state leakage current: 10 uA
Service Life: Unlimited
Bounce Time: None
5407
Type
  • Sealed mechanical relay
  • Form A (normally open) contacts.
  • Can be modified for Form B (normally closed) contacts.
Contact Ratings:
  • 6 A at 250 VAC resistive loads
  • 6 A at 30 VDC resistive loads
  • 3 A maximum in Class 1, Div, 2 hazardous locations.
Operating Frequency: 18,000 operations/hour mechanically, 1,800 electrically at rated load
Service Life:
  • 1,500,000 operations at 0...250 mA load
  • 600,000 operations at 1 A resistive load
  • 100,000 operations at 6 A resistive load
  • 300,000 operations at 1 A inductive loads with pf =0.4
  • 100,000 operations at 3.5 A inductive loads with pf=0.4
Operate Time: 10 ms maximum, 5 ms typical
Release Time: 10 ms maximum, 2 ms typical
Bounce Time: 3 ms typical
Contact Isolation: 1000 VAC
Logic Isolation: 1500 VAC
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 7
Joel_Weder
Captain
3
3130
Joel Weder
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
2
3121
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Abanoub
Ensign
Posted: ‎2021-12-21 11:23 PM
In response to BevanWeiss
3110
@Joel_Weder, @BevanWeiss Thanks for your concern!
The problem is that 5409 doesn't exist on BuyAutomation and i think it is obsolete so do 5407.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Abanoub
Ensign
Posted: ‎2021-12-23 01:38 AM
3087
Pretty clear, Thanks all!
However, we received a clarification from the customer asking to know the internal built-in relays type in module 5415 compared with the old type Omron relays in the obsolete module 5407.
Can we get this data?
@Joel_Weder, @BevanWeiss, @MartinChartrand
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Contact rating:
Switching Capacity:
Service Life:
Load current:
  • 9 A peak, 100ms
Bounce Time: None
5407
Type
Contact Ratings:
Service Life:
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-12-23 05:20 PM
The internal part numbers would not be guaranteed for either the old or the new IO modules.
These may vary from time to time, hence only the final product specifications would be guaranteed.
You'd likely find that the 5415 relays will have a faster response than listed, and may indeed be identical internal relays to the 5407.  But you shouldn't rely on this information, and Schneider could change the relays used in the 5415 with some that work slower (as long as they are still within the published specifications).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
