New SCADAPACK 334E Configuration Corrupt Error
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • New SCADAPACK 334E Configuration Corrupt Error
Joel_Weder
Captain Joel_Weder Captain
84
BevanWeiss
Spock BevanWeiss
23
sbeadle
Kirk sbeadle Kirk
17
MartinChartrand
Captain MartinChartrand Captain
15
Posted: ‎2021-05-30 03:37 AM
1529
I am new to the Scada pack RTU. I have seen couple of videos to get started with 334E RTU. But I have encountered error Below are the images:
What is the problem and what should I do?
  • DNP3
  • RTU
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-05-30 10:03 PM
Do you have a valid configuration in the RTU?
Configuration Corrupt would make complete sense if it was 'empty' i.e. unconfigured.  Or if you downloaded a configuration into it that was indeed corrupt (i.e. not valid).
The Function Code not implemented I'd probably just ignore until you get rid of the Configuration Corrupt.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Joel_Weder
Captain
Posted: ‎2021-05-31 09:08 AM
Bevan's reply may have contained enough information to lead you to a solution. If not, however, please feel free to contact our Technical Support team. When you do, make sure you give them as much information as possible. Eg:
- RTU model
- Firmware in the RTU
- Any logic or E Configurator configuration already in the RTU
- Logic or config file you were attempting to load into the RTU
- And the same error screen capture you posted here
You can contact our Tech Support team using either of these two methods:
Phone:  1-888-226-6876
Email:  supportTRSS@se.com
Joel Weder
Remote Operations Specialist
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
