[Imported] What is Level 2 Non-Packet Modulation ?
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] What is Level 2 Non-Packet Modulation ?
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Trio Licensed Radios
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 12:47 PM
>>Message imported from previous forum - Category:Trio Data Radios<<
User: joelw, originally posted: 2018-10-17 17:59:49 Id:60
**_jweder:_**
_____________
The E Series licensed radios have a modulation type called 2 level Non Packet mode. This type is chosen under one of two circumstances.
1) The user wishes to communicate using SEL Mirrored Bits protocol. This mode reduces latency to a minimum. (approximately 7ms)
2) The user wishes to use the radio to communicate with MDS 4710B radios. (only the 4710B is supported, no other, but this is a very common type)
Certain features are disabled in this mode:
- Port B
- No Flow Control mode (Hardware Handshaking required)
- Over the air diagnostics (local diagnostics does work)
- Repeat and Translate functions (Store & Forward can be done if an external loopback plug is used)
- 128 bit AES Encryption
- Remote programming
- Collision Avoidance
- Transmit Auto on Data (must use RTS)
  • Radio
Replies 0
