[Imported] Max DLog records in a 4203?
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] Max DLog records in a 4203?
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Flow Measurements
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 01:21 PM
>>Message imported from previous forum - Category:Realflo Electronic Flow Measurement<<
User: mchartrand, originally posted: 2018-10-17 18:51:56 Id:83
**_loot24:
Can anyone tell what the maximum number of DLog records that a 4203 will hold?_**
___________
mchartrand:
The 4203's DLOG will hold approximately:
TelePACE-based 4203: 19.3K words
ISaGRAF-based 4203: 21.4K words
______________________
**_loot24:
So 19300 records in a Telepace configuration?_**
___________________________
mchartrand:
This is not the number of records, it's the number of total words of data. The number of records is a factor of the number of words used per record in the DLOG configuration.
In short, if a DLOG is configured to log a time/date stamp (4 words) and three analog inputs, (1 + 1 + 1 words), this uses 4 + 3 = 7 words each time a record is created. To determine the maximum number of records possible with this configuration, you would divide 7 into 19,300 = 2,757 records.
Note: if you have more than one DLOG, then you have to take all DLOG usage into account at the same time. 19.3K is for all DLOGs, not per each DLOG.
I hope this helps!
  • RTU
Replies 0
