[Imported] Comunicating with Omron PLCs using Trio Data radios
Remote Operations Forum
Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Send InviteCancel
Posted: 2019-10-2512:26 PM
>>Message imported from previous forum - Category:Trio Data Radios<< User: joelw, originally posted: 2018-10-16 21:42:12 Id:35 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum.
**_ingcesarduque: Does anyone do something like this? (Comunicating with Omron PLCs using Trio Data radios)_**
Hello Cesar,
I am not sure what protocol the Omron PLC uses, but our Trio radios can handle virtually any normal serial or ethernet-based protocol. The packet layer in our serial-only radios can be configured to handle Modbus, DNP3 or many other protocols. If none of the choices works for you we have a Custom selection which allows you to specify how to packetize the data from your PLC's.
