Citect Equipment Parameter Address Offset
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Citect Equipment Parameter Address Offset
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Citect SCADA
Posted: ‎2021-08-02 04:19 AM
3105
I have a M580 PLC, the PLC tags are by numbers, for example a AI module PIT0101 FB instance tag addresses are %MW1000 to %MW1050.
If I want to use the equipment editor in Citect to create a equipment model, how do I indirect address these tags?
For example,
PIT0101.input = %MW1000
PIT0101.EUMax = %MW1001
Is there any way I can use offset in the equipment parameter so I just need to indicate the start address, then the rest of tag addresses will use offset.
PIT0101.input = %MW(startAddress)
PIT0101.EUMax = %MW(startAddress + 1)
Is it possible in Citect Equipment Editor?
Many Thanks
Chao
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-08-03 05:58 PM
3091
I'm not a Citect guru here, but my understanding is that each entry in the Equipment model must stand-alone, and so you can't have it reference anything else.
You can often just use an Excel file to generate the entries.  But additional modifications aren't as simple as only changing one location, you'd need to take them into Excel, do the calculations, export back out.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
3092
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2021-08-06 03:27 AM
In response to BevanWeiss
Mate, Thanks for the answers.
Looks like import/export to excel with macro is the way to go.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Timmy
Timmy
Cadet
Posted: ‎2024-09-21 06:34 PM
Hi, you can use any custom field to declare the prefix of tag address and add the fixed part of tag in the equipment editor.
Hope this help
