Unregistered Cards display
Rack access
Send InviteCancel
Register one or more rack access cards swiped at a Rack Access Pod 170 device, and not registered to the associated NetBotz Appliance.
Note
You access this display from the "Rack Access Settings" display Show Unregistered Cards link, available only when a rack access card swiped at device for the selection has not been registered.
Element
Description
List
Card ID#: The identification number assigned to the card.
Timestamp: The date and time the rack access card was swiped.
Register
Select to register the selected rack access cards.
Remove
Select to remove the selected unregistered rack access cards from the list.
Remove All
Select to remove all unregistered rack access cards from the list.
