Edit Rack Access Card display
Rack access
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Rack access
  • Edit Rack Access Card display
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Rack access
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Modify the settings, with the exception of the card ID #, for a rack access card.
Element Description
Card ID # The number assigned to the rack access card cannot be modified.
Note
You can use the "Add Rack Access Card" display to add another card and copy settings to it.
User Name Modify the user name assigned to the card.
Description Modify the description.
Requires Authorization Card Swipe Specify whether a swipe from an additional card is required to authorize rack access.
