NetBotz Appliance Rack Access Settings display
Rack access
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Rack access
  • NetBotz Appliance Rack Access Settings display
  • Mark as Read
  • Unregistered Cards display
  • Schedule Access display
  • Rack access control display
  • Rack Access Settings display
  • Edit Rack Access Card display
EcoStruxure IT Support
Request Support
Back to Rack access
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Identify the HID proximity card type used for the selected NetBotz Appliance, and specify the auto lock timeout. All cards registered to the NetBotz Appliance must use the same card type.
The "NetBotz Appliance Rack Access Settings" display appears the first time you access the Rack Access Settings option for a selected NetBotz Appliance. You can specify one of four supported HID proximity card types:
  • H10301 - Standard 26-bit
  • H10302 - 37-bit without a facility code
  • H10304 - 37-bit with a facility code
  • CORP1000 - Corporate 1000
You can access the display again, if needed, from the NetBotz Appliance Settings link in the "Rack Access Settings" display. You can modify the Auto Lock Timeout only. To modify the supported card type, you must first remove all the cards associated with the appliance.
The Auto Lock Timeout determines how long the device will wait (10 - 60 seconds) until it automatically locks the rack door after a card, a key, or a remote command is used to unlock it. If the door is open or the handle is up after the timeout expires, the device will issue the lock command until the door is closed and the handle is down.
Additionally, the Auto Lock Timeout limits the time the device will wait for a second authorizing card swipe after a rack access card that requires authorization is swiped.
Element Description
Card Type The type of HID proximity card registered to the NetBotz Appliance selected. You can specify the card type once only.
Auto Lock Timeout Specify the time the device will wait until it automatically locks the rack door after a card, a key, or a remote command is used to unlock it (10 - 60 seconds).
