Posted: 2021-05-26 07:09 AM . Last Modified: 2023-12-04 07:44 AM
📌 Which product can I customize and how?
- Push Buttons Caps, Plastic Bezel, Selector Switch Label, Boxes, .... and more:
- See pdf file in attached (Customization_Customer_Journey)
- See pdf file in attached (Customization&Robustness)
- See pdf file in attached (Customization_Customer_examples)
How I can customize my products
When the sales are stopped on a catalog reference with marking, a solution is to switch to a customized reference.
To avoid having to design it by yourself, this has already been done by me.
I propose you to find in the attached file the correspondence between discontinued references and new customized references. It will be enriched each time new replacement customized references are created.
See Substitution ref in attached.
To place one order see here page 4:
- Tags:
- english
Posted: 2021-11-30 04:50 AM
Is it possible to customize ATEX control station (XAWF130EX)?
If yes, could you confirm that the ATEX certificate is still valid?
Thanks for your help
- Tags:
- english
Posted: 2021-11-30 04:53 AM
Hello Christian,
XAWF is not customizable for now : only XALD and XALK control boxes can be customized for now
- Tags:
- english
Posted: 2021-11-30 05:40 AM
Thanks for your quick answer.
What about using a legend panel for XAWF130EX ATEX control station?
- Where can I find the cut-out for this enclosure (XAPA cut-outs are available in Tips & Tricks but nothing for XAPM or XAWF)?
- Is the ATEX certification still valid with the legend panel?
Best Regards,
Christian
- Tags:
- english
Posted: 2021-12-09 01:40 AM
Official position about this Topic:
Adding non-metallic components (including legend panel) to an ATEX enclosure should follow IEC 60079-0 rules, more specifically the article 7.4 concerning the electrostatic charges.
Regarding the ATEX enclosures XAWF* group (IIc) and their protection level (Gb) and regarding the nature of the legend panel plastic and its thickness, the surface of the label would be limited to 2000 mm² to keep ATEX certification.
In conclusion, it is not possible to propose a legend panel even for the smallest enclosure XAWF130EX
You will not find legend panel cuts for the ATEX enclosure
- Tags:
- english
