PowerLogic T300 - How to configure the ATS GEN function
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - How to configure the ATS GEN function
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic T300
Back to Protection & Control
Ray_Chang_EPEC
Lieutenant | EcoXpert Master Ray_Chang_EPEC Lieutenant | EcoXpert Master
Posted: ‎2022-12-26 12:33 AM . Last Modified: ‎2025-05-26 12:33 AM
2815
Hi:
  This is the first time that we are setting up a T300 system. We want to use T300-ATS for a standby generator system.
  • Self-return mode will be our choice: but we can't find where this mode can be set.
  • We try to use HU250's digital output to start the generator: it this possible?
  • We got a setting for this system but can't find all what is needed to set a value.
  • Where can I find a reference for typical T300-ATS setting?
Thanks if anyone can help on first time setting.
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (1)
  • PowerLogic T300
Tags (5)
  • PowerLogic T300
  • t300
  • T300 ATS
  • T300 GEN
jean-luc_batard
Lieutenant JG jean-luc_batard Lieutenant JG
Lieutenant JG
Posted: ‎2023-01-02 08:26 AM
Hi Ray
Yes Easergy T300 provides Automatic source transfer functionality, including selection of return mode
Here is the corresponding setting as described in User's manual
"Allow back to normal source" p 144 and detailed on page 148. Select "YES" in your case
"Controls the behaviour after a transfer to the backup source and
voltage returns on the normal source.
"No" means that the ATS waits for voltage absence on the backup
source.
"Yes" means that the system transfers back to the normal source.
"Use a variable" means that back to normal is enabled depending on the
value of a variable (coordinate AATS_BLK_SELF_RE
T)"
Note that native automatism is meant to manage 2 normal/backup sources.
It may be easily adapted to manage a normal source and a generator
For this follow attached application note
Jean-Luc BATARD
Distribution Automation Senior Application Engineer
jean-luc_batard
Lieutenant JG
Hi Ray
source.
T)"
Jean-Luc BATARD
Ray_Chang_EPEC
Posted: ‎2023-01-02 11:53 PM
Hi @jean-luc_batard :
    Thanks for the document. We'll check for detail.
    One more question is does the ATS setting in T300 by default?
    Or i need to add in like this video by Easergy Builder?
    https://www.youtube.com/watch?v=lPYYkBbsWVU
    I did see some set up need to be added by Easergy Builder in document.
    Cause we don't have any experience on Easergy Builder.
    We may have to check how to use Easergy Builder first or
    We can set by Web on T300 if the ATS setting is in T300 by default.
    Many thanks
