Hello everybody
Our clients is interested in monitoring temperature and he asks. How many sensors TH110 can support the T300 RTU?. The application is for installing in several SM6-36 inside a MV substation (24.9KV).
Thanks ind advance. @vladimirdo
Do you mean how many TH110/CL110 sensors can be connected to Easergy HU250 embedded ZigBee modem?
I believe up to 60 units.
Yes, limitation is 60 sensors in total
Take care however of the full size of your SM6 equipment(s) if many cubicles in it: zigbee comm will have to cross twice the metallic enclosure, reducing the range to a few meters
Regards
