PowerLogic T500 - Mapping multi Status points to one holding register in Modbus Slave
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T500 - Mapping multi Status points to one holding register in Modbus Slave
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
MinQV
Crewman MinQV
Crewman
Posted: ‎2025-08-18 03:09 AM . Last Modified: ‎2025-08-25 05:49 AM
517
Dear Experts,
I'm using the T500 module to collect data from DI/DO/DO modules. Now I want to create a Modbus Slave for others to read values. With "Status" points, do we have any way for mapping multiple points to one holding register?
  • PowerLogic T500
Tags (4)
  • modbus
  • PowerLogic T500
  • slave Modbus device
JuanRayo
Lt. Commander JuanRayo Lt. Commander
Lt. Commander
Posted: ‎2025-08-25 02:16 AM
490
Hello MinQV.
Yes you can .
using Formulas you will be able to gather different booleans in just one package to be sent upstream as a holding register .
I am attaching an example where some booleans (from IEC61850) are multiplied by a factor (1*, 2*, 4*, 10*,....) which determine the position in the holding register to be transferred. Hope this suits your needs.
JuanRayo
Lt. Commander
491
Hello MinQV.
Yes you can .
MinQV
Crewman MinQV
Crewman
Posted: ‎2025-08-25 08:20 PM
Hello JuanRayo,
Thank you for your advice. Regarding the factors, I saw that you use 10, 20, and 40. Where can I find this value for the formula?
JuanRayo
Lt. Commander
Posted: ‎2025-08-26 12:06 AM
Hello MinQV.
Basically the multiplier factor is in Hexadecimal if you convert it into binary you´ll see the bit/position in the word where the boolean signal will be located.
Here you are the factors.....you can check then out with a calculator: 1,2,4,8,10,20,40,80,100,200,400,800,....
