PowerLogic T300 - SC150 compatibility with Holmgren CT wiring for Earth Fault detection
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - SC150 compatibility with Holmgren CT wiring for Earth Fault detection
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
40
Arun-kumar_PS
Arun-kumar_PS Mentor
33
PowerLogic T300
Back to Protection & Control
jean-luc_batard
jean-luc_batard Troubleshooter
Troubleshooter
Posted: ‎2024-11-05 12:26 AM . Last Modified: ‎2024-11-25 03:22 AM
1643
Hello All
Here relaying some question from DSPS
Does PowerLogic T300 support following CT cabling, known as Holmgreen connection ?
If yes, does it work with current firmware and what should be the settings?
What is the difference with a classical 3 phase CT mounting and calculating I0 by summing the 3 currents by software ?
Jean-Luc BATARD
Distribution Automation Senior Application Engineer
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (1)
  • PowerLogic T300
Tags (5)
  • CT cabling
  • Earth Fault
  • Holmgreen
  • t300
Gregory_M
Gregory_M Mentor
Mentor
Posted: ‎2024-11-12 02:00 PM
Hi Jean-Luc,
I don't know the T300 specificaly, but if the device can perform earth fault detection from a dedicated input, I don't see anything that prevents Holmgreen connection.
Holmgreen connection or summing the 3 currents by software are kind of redundant.
They both face the same limitations regarding sensitivity and stablity against inrush current compared to dedicated Core balance CT.
Rajasekar_Chandrasekar
Rajasekar_Chandrasekar Contributor
Contributor
Posted: ‎2024-12-10 10:45 PM
1506
Hello Jean-Luc,
I think this connection is not tested and we don't have this connection can be set in the T300 setting of SC150 Page. we need to ask R&D team. if posisble we have add the setting option in the SC150 setting page.
BR
Rajasekar
JYPOC
JYPOC Mentor
Mentor
Posted: ‎2024-12-12 02:57 AM
Hello Raj,
Mathieu has successfully tested the solution but as Gregory wrote, the result is not better than with the calculation based on the 3 CTs...
BR - Jean-Yves
