PowerLogic T300 - How to replace an old Easergy T200 controlling an RM6 RMU?
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic T300 - How to replace an old Easergy T200 controlling an RM6 RMU?
Araceli_Monje
Araceli_Monje Mentor
60
Arun-kumar_PS
Arun-kumar_PS Mentor
26
JuanRayo
JuanRayo Mentor
24
RM6
Easergy T200I/T200E
PowerLogic T300
Back to Protection & Control
RuchirSomani
RuchirSomani
Explorer
Posted: ‎2025-02-18 09:50 PM . Last Modified: ‎2025-03-17 12:58 AM
1716
We are facing a typical challenge when trying to retrofit T300 in place of T200 which is integrated with RM6.
Pin No. 1 of Interface Card Channel and well as Pluggable connector servers as DI common and as well as continuous negative supply for Command(For Motor Supply) in case of T200. Please find attached diagram from T200 installation manual as well as RM6 manual.(Refer Figure 1A and 1B)
However in case of T300, DI Common reference has 0V which seems to be isolated from the external 24Vdc power supply. Hence, this DI Common (Pin No. 9 of DI slot) cannot server purpose of the extending Negative (-ve) voltage reference at Pin No. 1 of Pluggable Connector. (Refer RM6 side connection Figure 2)
Please confirm whether is there any way to complete the retrofitting without making any wiring termination changes at RM6 TB side as shown in Figure 3.
@Paco @jean-luc_batard
Thanks & Regards,
Ruchir Somani
  • Thumbnail of RM6
    RM6
  • Thumbnail of Easergy T200I/T200E
    Easergy T200I/T200E
  • Thumbnail of PowerLogic T300
    PowerLogic T300
View products (3)
  • Application cases
  • PowerLogic T300
Tags (4)
  • Eaergy T200
  • PowerLogic T300
  • RM6
Mathieu_Lansoy
Mathieu_Lansoy Mentor
Mentor
Posted: ‎2025-03-14 09:44 AM
As explained in this document, the "DI common" and the "0V" can be separated, or can be mutualized (which is the case in the context of T200 retrofitting).
  Mathieu.
Mathieu_Lansoy
Mentor
  Mathieu.
