Micom P633
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Micom P633
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
Hoang_Phu
Ensign Hoang_Phu
Ensign
Posted: ‎2025-03-11 02:34 AM
774
Micom P633
Hello guys, I am unable to read IEC61850 data from Micom P633 relay. If you have successfully read IEC61850 data from this relay, please share your experience. I would be grateful if you could give me an example to guide me.
  • IEC61850
  • MiCOM range
  • PowerLogic P3
  • PowerLogic P5
sesa164970_brid
Lieutenant JG sesa164970_brid Lieutenant JG
Lieutenant JG
Posted: ‎2025-03-13 01:33 AM
Reading IEC61850 data from P633 is possible however it needs proper configuration.
In general, you should have:
• Easergy Studio (ES) tool,
• Device with the Ethernet board (check visually if device has got RJ45 port described as ETH C)
• User details (credentials) to work with the device
• USB connection between PC and P633
Then:
1. With ES - activate IEC61850 (change values to match your application):
  056.059 IEC Function group IEC = With
  104.000 IEC General enable USER = Yes
  104.077 IEC IEC 61850 enable = Yes
  104.080 IEC ETH COMM Mode = PRP
  105.182 IEC RSTP enable = No
  104.084 IEC IEC prot. variant  = IEC = IEC 61850 ED2
2. Send these parameters to the device
3. Create new CID file and configure it with IED Configurator (part of ES tool), define connection’s parameters together with datasets/rcb/GOOSE
4. Send configured CID file to the device
sesa164970_brid
Lieutenant JG
Then:
Hoang_Phu
Ensign Hoang_Phu
Ensign
Posted: ‎2025-03-13 06:43 AM
Can I try it and get back to you? @sesa164970_brid
