I want to ask something. I have been using IEC61850 for a while. I want to read the IEC61850 CID file with T300 Rtu and control the breaker remotely. But I can't configure the control. As I understand it, Control/Control Object/Control/XCBR1/Pos is used to control this method. But I can't connect it to the Digital output that I need to control. How do I connect Breaker open 1402, Breaker Close 1401 and control what am I missing? On Easergy P3 and P5, I used to set it up on the output matrix before. Or do you have any example PDFs?
Hi, as no reply has been received for this request for more than 3 months, I consider a solution was found for this topic @Hoang_Phu , so I am marking this case as solved. Do not hesitate to contact us again if your topic has not been solved, thx.
@Arun-kumar_PS , could you please support with this question or guide @Hoang_Phu to the right person that is able to support with this topic?, thx.
