MicroLogic 6.0 X erroneous trips
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • MicroLogic 6.0 X erroneous trips
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
38
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
Jonathan_H1
Jonathan_H1
Explorer
Posted: ‎2025-06-13 08:02 AM . Last Modified: ‎2025-06-13 11:40 AM
735
We have a Micrologic 6.0 X in a MTZ2-32H3 3200 amps. This is a 480V CAT rental generator.  We had a customer that was getting erroneous ground fault trips every 3 to 4 closures of the breaker. They were stepping up 12kv with about 1.8mega watt bulk load. This machine was trying to be used at a hospital unfortunately we had to send another unit. Going through the settings every thing is turn up to the maxes and it was still happening.
Is there anything that can be done?
Also is there a way to testthe ground fault safely on 3ph
  • Application cases
  • Training
Araceli_Monje
Mentor
Posted: ‎2025-07-29 08:24 AM . Last Modified: ‎2025-07-29 08:25 AM
Dear @Jonathan_H1 , Micrologic is not inside the portfolio managed in this Protection & Control Forum, my apologies. I would suggest you to post your question in the Power Distribution Forum, our colleagues there may be able to support you or connect you with the right people that are able to help you with your question , Power Distribution and Digital Support - Schneider Electric Community
Araceli_Monje
Mentor
