How to configure Power Operation to read 64 bit values via modbus protocol
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • How to configure Power Operation to read 64 bit values via modbus protocol
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
EcoStruxure™ Power Operation
Back to Protection & Control
Hoang_Phu
Ensign Hoang_Phu
Ensign
Posted: ‎2025-03-30 04:51 AM
926
Hello guys, Im reading the line voltage value from the P3 relay. This value is more than 65535, so i cant read it. Please help me. How to adjust it?
  • Thumbnail of EcoStruxure™ Power Operation
View products (1)
  • PowerLogic P3
Frank_Wang
Ensign Frank_Wang Ensign
Ensign
Posted: ‎2025-04-22 06:42 PM
May I know which value you want to read from P3 relay?
Because as I know, in P3 relay, all the values are kept within 16 bits.
And normally the scaling setting will be sufficient to keep the value within 65535.
So my understanding is that we may not need to configure it in PO, normally no special action is required, because most default scaling setting in P3 is sufficient.
I have attached a Modbus configuration application note for P3 for your reference.
Hope this can help.
Best regards,
Frank
Frank_Wang
Ensign
Hope this can help.
Best regards,
Frank
Hoang_Phu
Ensign Hoang_Phu
Ensign
Posted: ‎2025-07-11 12:57 AM
thank you, this works
