Device template error in PME
Power Monitoring and Energy Automation NAM
This forum is created for the exchange of information and open dialogue regarding electrical power monitoring and energy automation products and services. Participants will have access to downloadable material as well as chat opportunities with subject matter experts.
  • Power Distribution NEMA
  • Power Monitoring and Energy Automation NAM
  • Device template error in PME
Charles_Murison
Picard Charles_Murison Picard
7
Michael_Neas
Ensign Michael_Neas Ensign
3
Robert_Lee
Admiral Robert_Lee Admiral
2
PowerLogic PM5000 series
Back to Power Monitoring and Energy Automation NAM
Salah_Mohamed
Ensign Salah_Mohamed Ensign
Ensign
Posted: ‎2024-01-30 06:46 AM
1825
Hello
I’ve an issue that  Power tag rope  or NSX  or Power tag 63 A
When trying to call device template diagram as per this video: https://www.youtube.com/watch?v=unzAfcOBf5A  ,it refuses  and appear attached message  although  the template diagram is available in  PME folder in C as per attached photo
Also ,tried to open device type editor  in management console and try to add template manually  but never accept as per attached photo, what’s your advise to solve this issue ?
  • Power Monitoring Expert (PME)
  • power tag
Charles_Murison
Posted: ‎2024-03-08 11:04 AM
Hello @Salah_Mohamed ,
It can be a little tricky to determine exactly the root cause of what you are seeing. This could be a simple as PME is not communicating with the device to more complex interactions between PME and windows Registry. When selecting diagram from meter's template. PME takes a number of steps. First is to find the DeviceInfo key in windows registry, then find the device type key, then defaultFirmware then device specific information.
You can see example below.
The information the data field is if the folder and diagram name PME will try to open. There are a lot of moving parts and determining where something has gone wrong can be a challenge. I would start by using a program called procmon from live.sysinternals.com. You can see all of the keys/values PME is trying to access when opening the diagram. Perhaps PME is not opening the devicetype you think it should. Or value in data field does not match what folder and diagram are called. Or folder and diagram names do not match.
There is sadly not a single answer to explain why you are seeing this error.
Charles
