Backfeeding a generator?
Power Monitoring and Energy Automation NAM
This forum is created for the exchange of information and open dialogue regarding electrical power monitoring and energy automation products and services. Participants will have access to downloadable material as well as chat opportunities with subject matter experts.
  • Power Distribution NEMA
  • Power Monitoring and Energy Automation NAM
  • Backfeeding a generator?
Charles_Murison
Picard Charles_Murison Picard
7
Michael_Neas
Ensign Michael_Neas Ensign
3
Robert_Lee
Admiral Robert_Lee Admiral
2
Back to Power Monitoring and Energy Automation NAM
wexxs
wexxs
Cadet
Posted: ‎2024-08-11 02:53 AM
654
Back feeding a generator?
I keep reading this is a No No but some people insist it’s not bad as long as you turn off your main electric supply… any thoughts?
I think back-feeding is the right term, but in case I’m using the incorrect term: it’s the practice to plug in a generator to a walloutlet to provide energy to some areas of your house.
router login 192.168.l.l
  • Utility Metering
Charles_Murison
Posted: ‎2024-08-19 11:52 AM
Hello @wexxs
I am not an electrician and I am not familiar with your local electrical safety codes so please that that into consideration with this reply.
Usually outlets in a house have a 15 Amp circuit break. This means your generator, if connected to outlet would would be able to supply at most 15 A of power to other areas. Unlikely that generator is connected to outlet.
However if your generator is connected to the main feeds, this breaker is much larger and possibly able to supply power more reliably. When I have seen generators connected to a home system, there almost always an automatic transfer switch that will switch feed from utility to generator under different conditions.
Connecting a generator directly to mains without some kind of control is asking for trouble and I would not recommend it.
Charles
