Ecostruxure Power Commission hangs at startup.
  • Power Distribution IEC
  • Ecostruxure Power Commission hangs at startup.
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Dave_Trenaman
Lieutenant JG Dave_Trenaman Lieutenant JG
Lieutenant JG
Posted: ‎2022-08-03 01:09 PM
2642
No luck running EPC 2.25 on my corporate SE laptop. Get past the single sign on but app just hangs on the splash screen. Progress bar at the top advances then retreats, advances then retreats. Tried running as admin but same behaviour. Re-installed a few times. No installation errors.
  • Software
EPC_Leader
Lt. Commander EPC_Leader Lt. Commander
Lt. Commander
Posted: ‎2022-08-04 01:14 AM
4
2629
Hello Dave
As I installed that release in my corporate laptop few days ago without issue, I thing you should have a laptop configuration issue ( memory, firewall conf, DD free space, internet com,... ), I advice you to contact the IT dept to solve the issue.
Replies 5
EPC_Leader
Lt. Commander
4
2630
Hello Dave
Dave_Trenaman
Lieutenant JG
Posted: ‎2022-08-08 07:21 AM
In response to EPC_Leader
2563
Not RAM - 32GB
Not DD - 100+GB Free space on SSD
Not CPU - 6 core i7
Fast internet.
App goes through auth with IDMS  and then hangs. Appreciate you can't give support for SE corporate IT security, I suspect they will say the same about EPC. Any logs or error traces the app might create that I can troubleshoot? Any known ports EPC uses?
EPC_Leader
Lt. Commander
Posted: ‎2022-08-08 07:39 AM
In response to Dave_Trenaman
2556
Hello Dave
I don't understand why IT support doesn't want to help,  but in my side I can give you the email adress of our EcoStruxure Power Commission technical team :
fr-ecob-fi-globalsupport@schneider-electric.com
Regarding the log error managment, we have a specific function providing all the log files in one clic in the EcoStruxure power Commission home page, very usefull for our technical support, but to have access, you have to pass the installation step
Best regards
Dave_Trenaman
Lieutenant JG
Posted: ‎2022-08-09 09:01 AM
2537
I think there is a misunderstanding. EPC is fully installed. No observable installation errors. The issue is when I start the app, I log in using single sign on, authentication is successful and then the app hangs.
Thanks for passing along the email. Before I open contact support,  I was hoping to do some info gathering on my end. Does EPC produce any error logs? Does EPC have any special network requirements like ports it needs open? Does EPC have any special privilege requirements like running as administrator?
EPC_Leader
Lt. Commander
Posted: ‎2022-08-09 10:58 PM
Hello Dave
The answer to your question :
YES, but reachable on the home page
No
No, but time to time we can have some IT constaint blocking the installation or the running of the soft.
