Network Management System Integration option
Send InviteCancel
Specify trap receivers (Network Management System consoles) to which the server will send SNMPv1 traps and SNMPv3 informs.
This option accesses settings used to enable the Data Center Expert server to send SNMPv1 traps and SNMPv3 informs to defined Network Management System consoles for alarms that occur at monitored SNMP devices and NetBotz Appliances, and the devices associated with those appliances.
Note
For information about the SNMPv1 traps and SNMPv3 informs that the Data Center Expert server can send, see the latest version of the APC PowerNet MIB available for download at https://www.apc.com/us/en/tools/download/
