Test trap failures
Network Management System Integration
  • EcoStruxure IT Help Center
  • DCE configuration
  • Network Management System Integration
  • Test trap failures
  • Mark as Read
  • Network Management System Integration option
  • Network Management System Integration display
EcoStruxure IT Support
Request Support
Back to Network Management System Integration
  • Mark as Read
Test trap failures
Picard EcoStruxureIT
‎2019-11-20 06:15 AM
A Network Management System listed as a trap receiver in the DCE Network Management System Integration display can fail to receive a test trap if there are problems with the settings used, or with the network.
Note
If the problem persists, contact APC Support (http://www.apc.com/support).
Problem Recommended Actions
Settings
Make sure the "SNMPv1 Trap Settings" display or "SNMPv3 Inform Settings" display settings associated with the target Network Management console are properly defined.
Make sure the SNMP settings have not changed at the target Network Management System console, and that the appropriate SNMP service is enabled at that console.
Network
Make sure the device was not turned off or disconnected from the network when the test trap was sent.
Correct any network connection problem.
