Modifying an alert action
Monitoring NetBotz Appliances in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Modifying an alert action
  • Mark as Read
  • NetBotz Appliance Polling option
  • NetBotz Appliance Alert Notifications overview
  • Managing numerical and state alert thresholds
  • Managing alert profiles
  • Creating an alert action
  • Alert Thresholds options
  • Alert Profiles option
EcoStruxure IT Support
Request Support
Back to Monitoring NetBotz Appliances in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
You can use the same basic procedure to modify any type of alert action.
  1. Select "Alert Actions" in the Alert Settings option in the NetBotz Appliance Configuration option in the Device menu.
  2. In the "Select Alert Action Type" display, highlight the type of alert you want to modify, and click Next.
  3. In the "Select Next Action" display, select to modify an action, and click Next.
  4. In the "Select Devices" display, select the parent device or devices associated with the alert action you want to modify, and click Next.
  5. In the "Select Alert Actions" display, select only the alert action you want to edit.
    Note
    If you select multiple alert actions, the changes you make will result in those alert actions using the same settings and name.
  6. In the "Alert Action" display for the selected action, edit the settings, as needed, and click Next.
  7. In the "Test Action" display, click Finish without testing the action, or select the action you want to test, click Test Action, and then click Finish.
    Note
    You will need to verify the test was successful. For example, for a Send SNMPv1 Trap, verify the trap was received at the trap receiver; for a Send E-mail, verify the e-mail was received.
  8. In the "Choose Next Action" display, select whether you want to configure additional actions, add actions to alert profiles, or exit the "Alert Actions" wizard, and click OK.
