NetBotz Appliance Alert Notifications overview
Monitoring NetBotz Appliances in DCE
Send InviteCancel
The NetBotz Appliances monitored by the server each generate their own alert notifications in response to alert threshold violations that occur at the devices they monitor.
The NetBotz appliance stores its threshold settings and sends alert notifications to the Data Center Expert server. The Alert Settings options in the NetBotz Appliance Configuration option of the Device menu define how notifications are performed.
Alert Actions: Used to create, edit, or delete the alert actions which define how users will be notified of alarm conditions.
Note
You must create at least one alert action before your NetBotz Appliance can generate alert notifications.
Alert Profiles: Used to create, edit, or delete alert profiles that define the notification sequences to occur when a threshold is triggered.
Note
You must edit the default profiles, or add new profiles, to include one or more alert actions before your NetBotz Appliance can generate alert notifications.
Alert Thresholds: Used to define threshold settings that the NetBotz Appliances will use to monitor sensor values.
