Alert Thresholds options
Monitoring NetBotz Appliances in DCE
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Alert Thresholds options
  • Mark as Read
  • NetBotz Appliance Polling option
  • NetBotz Appliance Alert Notifications overview
  • Modifying an alert action
  • Managing numerical and state alert thresholds
  • Managing alert profiles
  • Creating an alert action
  • Alert Profiles option
EcoStruxure IT Support
Request Support
Back to Monitoring NetBotz Appliances in DCE
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
The allows you to create alert threshold settings for any sensor value reported for monitored NetBotz Appliances.
Two basic types of alert thresholds are available: those that use numeric settings, and those that use state settings.
  • Numeric thresholds:
    • Air Flow
    • Audio
    • Current (Amps)
    • Dew Point
    • Humidity
    • Other Numeric Sensors
    • Power (VA)
    • Power (Watts)
    • Temperature
    • Voltage
  • State thresholds:
    • Door
    • Door (Handle)
    • Door (Lock)
    • Dry Contact
    • Motion Sensor
    • Other State Sensors
Both types of thresholds allow you to do the following:
  • Create alert thresholds at one time for multiple sensors that monitor the same value (for example, all are Humidity sensors, or all are Door sensors) at the NetBotz Appliances monitored by the Data Center Expert server.
  • Assign a NetBotz Appliance alert profile to the specific sensor at the NetBotz Appliance the profile was created on, and to all the sensors on the devices it monitors.
  • Specify the severity for any defined threshold.
The Alert Settings menu in the NetBotz Appliance Configuration option of the Device menu provides access to the alert thresholds. Each Alert Threshold option allows you to search some or all of the NetBotz Appliances monitored by the Data Center Expert server for sensors that match the selected option. You can then edit or add thresholds for one of those sensors, or configure the same threshold for any number of those sensors, simultaneously.
