where to buy clamp on ct 5/5a
Metering & Power Quality
  • EcoStruxure Power & Grid
  • where to buy clamp on ct 5/5a
Charles_Murison
Picard Charles_Murison Picard
525
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
sesa149897_brid
Lieutenant JG sesa149897_brid Lieutenant JG
Lieutenant JG
Posted: ‎2013-08-30 01:47 AM
1185
We're using ION7650 meter as a power quality tool to do energy audit.
Sometime due to the big size of power cable (of incoming panel) which its diameter rather bigger than our clamp on CT (2000/5A), and this incoming panel had CT (2000/5A) already for customer's metering purpose. So, we're going to use our clamp on CT to measure the current at the secondary side (5A) of existing CT, by this way, we should use the clamp on CT with small ratio as much as possible, example 5/5A, 10/5A...
Does anyone know where to buy small ratio clamp on CT as mentioned?
Matt_Curry
Administrator Matt_Curry Administrator
Posted: ‎2013-08-30 09:55 AM
1140
Just moved to the Power Monitoring Hardware area.
Yu_Diao
Commander Yu_Diao Commander
Commander
Posted: ‎2013-08-30 02:05 PM
1140
Just a thought: why do use tie your ION meter to the exsiting CTs, as long as there is a CT shorting block u can accessan u can do this without a shutdown. The customer's existing meter should continue to work as normal when u wire these two in serial.
sesa149897_brid
Lieutenant JG
Posted: ‎2013-08-31 03:19 AM
Hi Yu Diao,
Can you share more detail (brand, catalog) on CT shorting block as you mentioned.
Thanks.
