Continue
  • My Subscriptions
  • Events
trouble setting up HDPM 6000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • trouble setting up HDPM 6000
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
GREG.KADERA
GREG.KADERA
Explorer
Posted: ‎2025-09-19 08:53 AM
701
hello I have been taking back and forth with the chat line Mehran and he has been great help but it seems to be a day of more for response and maybe its not the correct place for my issues. so I have 54 of the 6000 head units with the 6000s taps/channel boards. We just brought online one for testing, and I have set the IP and via the browser have setup the following. I am also able to modbus the register/points I need. We are not looking for the head unit to do any special group  grouping or calculations. we are just looking to pull the raw value off each channel/circuit. The issue is that reading that should be the raw amp's are for some reason almost double the manual amp clamp reading at the panel. I have attached a snip of the manual reading of 1,3,5,7,9,11 and what the meter is showing.
  • HDPM6000
Mehran_Mehrnia
Champion
Posted: ‎2025-09-22 09:31 AM
Hi @GREG.KADERA
I have already added my comments to the main topic "HDPM6000 Modbus integer registers".
The attached images to this post are not available and the one attached to the main topic is not clear enough to read the values.
Best Regards,
-Mehran
L3 Expert Advanced metering
Mehran_Mehrnia
Champion
Hi @GREG.KADERA
Best Regards,
-Mehran
