Continue
  • My Subscriptions
  • Events
What is the significance of the Parameter "Load Harmonics Rise" in Accusine Product?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • What is the significance of the Parameter "Load Harmonics Rise" in Accusine Product?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
varad
varad
Contributor
Posted: ‎2019-04-27 02:26 AM . Last Modified: ‎2020-12-02 03:31 AM
6
2935
Can anyody tell me what is the significance of  "Load Harmonics Rise" in Accusine Prouct? and how exactly it get calculated?
Also what is the acceptable rise?
  • Power Quality
Szymon_Hochół
Szymon_Hochół Champion
Champion
Posted: ‎2019-08-21 03:38 AM
4
2912
Could you please specify where exactly you find this parameter?
Installatuion of AHF in the electrical network makes a change in impedance seen from the load (AHF is low impedance vs the source). Because of this, running AHF causes a rise in harmonic currents drawn by non-linear loads. This is why you need to take a sizing factor into consideration when sizing AHF - to compensate this rise. I don't have details about the way this parameter is calculated in AccuSine but I can suppose it is simple comparison between harmonics values before and after the unit is turned on. Very high value of harmonics rise can be a symptom of resonance in the electrical network. You should not allow the harmonics to rise too much in order to protect the loads.
Hope this helps,
BR
Szymon_Hochół
Champion
Posted: ‎2019-08-23 12:13 AM
2
2899
the parameter on your screeen does not look good. As you can see, the filter is injecting some current in order to cancel harmonics (3-6% of its nominal current) but THDi values instead of getting lower become higher. This is because the AHF itself causes high rise in harmonics drawn by the load.
This is clearly a case for technical support, as it needs further investigation (which harmonic orders precisely became higher, what are the loads etc. etc.) I strongly recommend you contact them.
varad
varad
Contributor
Posted: ‎2019-08-23 08:20 PM
2895
Hii BR...
Than you very much for discussing over this topic. We will contact to the tech support.
Can you please share any study material related to this?
Szymon_Hochół
Champion
Posted: ‎2019-08-25 11:56 PM
Unfortunately I don't have any documents to share. This are topics covered during AccuSine trainings.
Replies 6
Posted: ‎2019-08-21 02:29 AM
Hello the community! Can you help @varad on this topic please?
Szymon_Hochół
Champion
4
2912
Hope this helps,
BR
varad
varad
Contributor
Posted: ‎2019-08-22 06:53 AM
2905
Hii...BR
Thanks for such informative reply. Please find herewith attachments of AHF Screens for Load Harmonics Rise. Is it the same parameter for which you are talking?
Szymon_Hochół
Champion
2
2899
varad
varad
Contributor
2895
Hii BR...
Szymon_Hochół
Champion
