What are the differences between a PM8240 and an ION7400?
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • What are the differences between a PM8240 and an ION7400?
Charles_Murison
Charles_Murison Champion
570
Mehran_Mehrnia
Mehran_Mehrnia Champion
202
Ramasamy_N
Ramasamy_N Champion
115
Philippe_Morel
Philippe_Morel Mentor
Mentor
Posted: ‎2018-03-19 08:54 AM
2630
Dear,
I can't find a clear table to show the differences.
Philippe
DanL
DanL Champion
Champion
Posted: ‎2019-10-03 02:40 PM . Last Modified: ‎2019-10-03 02:43 PM
Here's my unofficial list of differences between ION7400 and PM8000 (differences I'm aware of)
  1. display hardware differences:
    • ANSI type 2 optical communication port
    • USB virtual serial port
    • 2x additional (pre-configured) Wh and VARh optical pulse outputs
  2. Firmware feature differences:
    • Support for Flicker module
    • Support for Mains Signaling compliance modules (max 5)
    • Support for display value scaling and display scrolling
    • Support for 2 extra display modes (3 vs 1), and 20 more custom displays (40 vs 20)
    • Support for an extra 61850 connection (5 vs 4)
    • Support for extra 75 DNP Slave Export modules (100 vs 25)
    • Support for DLMS
  3. default Framework/Template differences
    • Transformer and Line Loss power compensation
    • Test mode framework
    • Extra display modes/screens
    • Flicker framework
    • Mains Signalling compliance framework
Yut
Yut
Leader
Posted: ‎2018-03-19 09:42 PM
2
2600
ION7400 has front ANSI optical port and two LED pulse output for VAR and WATT hour which is convenient for meter verification test the utility can perform accuracy test on both wh and varh easilily.
RafaelCiriaco
RafaelCiriaco
Contributor
Posted: ‎2019-10-03 05:21 AM
Additionally ION7400 can measure flicker, PM8000 does not have this feature.
DanL
DanL Champion
Champion
    • Support for DLMS
    • Flicker framework
