Posted: 2015-10-27 12:57 AM . Last Modified: 2020-04-20 02:54 AM
Hi
I want to know during the period we set, will Vigilohm continuously showing the measurement on display?
Posted: 2015-10-28 07:54 AM
Hello Abon chen,
I am not quite clear about your question, what period do you mean?
Posted: 2015-10-28 05:51 PM
The time delay period.
Posted: 2015-11-01 10:31 PM
I found that the Power Circuit mode in IM400 is what I need for the high disturbed environment caused by frequent start-up of VSDs.
By injecting low frequency current, IM400 can measure w/o being biased by capacitive loads.
However, if there is high frequency current in the environment, will IM400 be affected?
Posted: 2015-11-05 06:02 AM
Hi Abon Chen,
1. yes, power circuit mode is used to avoid frequency disturbances.
2. IM400 inject low frequency signal, will not be affected by high frequency current.
Posted: 2015-11-17 12:34 AM
Hi CHEN,
May I know if I can use IM400 with generators? I only see IM400 installed under transformer, not sure it can be applied with generators.
Abon
Posted: 2015-11-17 11:59 PM
please make sure it is IT system.
