The following parameters are not coming on the Easy UPS(E3SUPS40KH) MIB file. So kindly provide us same if possible ,
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • The following parameters are not coming on the Easy UPS(E3SUPS40KH) MIB file. So kindly provide us same if possible ,
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
Posted: ‎2020-04-29 03:49 AM
1
1310
Input current L1
Input current L2
Input current L3
Input Power Factor L1
Input Power Factor
Bypass Current L1 L2 L3
Bypass Power factor
Output Current L1 L2 L3
Output Power factor
Output KW
Output KVA
Charles_Murison
Champion
Posted: ‎2020-05-11 09:58 AM
Hello @Anonymous user   (recommend changing this name)
The group that supports this device likely does not check this particular forum. I recommend going to se.com -> support -> contact technical support to ask for this information.
Charles
Charles_Murison
Champion
Charles
