Continue
  • My Subscriptions
  • Events
Setting up reverse current alarm in PM820
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Setting up reverse current alarm in PM820
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2014-06-18 10:24 PM
1119
Hi
I've seen a default reverse power alarm in the manual but is it possible to set up reverse current alarm as well?
thanks
JamesAZZO
JamesAZZO
Leader
Posted: ‎2014-06-19 02:43 AM
I could be wrong but I believe current is not a vector and therefore only measures in magnitude in our power meters. The -kW implies a reverse current in most cases.
This is the same reason you don't get kVA values in the negative even when reverse power conditions. Voltage and Current magnitudes are always positive. You need the kW which is a vector calculation using a 4 quadrant formula. So stick with reverse kW in this case.
JamesAZZO
JamesAZZO
Leader
