Hello everyone !
Had an auxiliary module for an older power quality meter PM8M2222, that used its analogue input and digital output with relays.
I am replacing the old power quality meter with a PM8240, with auxiliary I/O modules:
- METSEPM89M0024 for analogue input
- METSEPM89M2600 for digital output
Can the new setup replace the funtionality of the old setup ? Is there way that I can configure my PM8240 so that I am only using the analogue inputs of the METSEPM89M0024 and the 2 digital output relay of the METSEPM89M2600 ?
Hello @Adam_Balazs,
What to confirm I understand your question. You have a PM800 meter, with expand module, 2 relay Outputs, 2 digital Inputs and 2 analog Outputs. You want to replace the PM800 with PM8000 and be able to still operate desired outputs.
I do not know exactly what on the PM800 meter was used to operate the outputs so I cannot save with 100% certainty the PM8000 will match. Chances are very high that PM8000 can do what PM800 did. Perhaps with some custom programming.
Regarding the PM8000 programming, it is possible to configure exactly what output the meter is going to use.
Charles
Hello @Adam_Balazs,
Charles
