Continue
  • My Subscriptions
  • Events
Reverse engineering transformer and line loss
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Reverse engineering transformer and line loss
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2014-09-09 08:35 PM
1647
Hi all,
A default ION 7/8000 series meter has frameworks for calculating transformer and line losses. If there is an error in the loss parameters and the meter goes into service, the uncompensated values are not logged anywhere. Since the incorrect compensated values must be corrected; does anyone have a method/spreadsheet to handle this scenario? I assume by reverse engineering the loss formulas with an assumed steady voltage, pf etc the amperage for each interval energy value can be derived?
Any thoughts greatly appreciated.
Tags (5)
  • accuracy
  • calculation
  • lines
  • losses
  • transformer
sesa46696_bridg
sesa46696_bridg Leader
Leader
Posted: ‎2014-09-12 04:53 AM
We have a number of customers that will modify their framework to record both compensated and uncompensated values, seems a bit safer if they program the meter incorrectly. Many customers will just do the compensation in MV90 rather than the meter.
