Continue
  • My Subscriptions
  • Events
Red light Watt ION9000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Red light Watt ION9000
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-15 10:03 AM
2529
Hi team,
I just install ION9000. But i see led red in Watt ION9000, pls explain for me, what is this. Thanks very much. ( attached img)
  • ION9000
Charles_Murison
Champion
Posted: ‎2022-03-15 10:19 AM
Hello @SESA528 ,
The ION9000 meters do not have integrated display. It is possible meter is installed without a display, the Wh LED will pulse (flash) after X amount of energy is "seen" by meter. The amount of energy is configurable with 1.8 being a default value. If you have PT and CT rations it is likely this is pulsing so much the LED just stays on.
Charles
Replies 4
Bojan
Bojan Leader
Leader
Posted: ‎2022-03-15 10:13 AM
2525
You should probably set Kt (pulse weight) setup register to be greater than default 1.8 Wh. in order to se a pulses
Kt (pulse weight)
This register defines the weight of the output pulse (i.e., how many energy units in Wh, VARh or VAh are accumulated before the module sends an output pulse to the hardware channel). A typical industry standard for energy pulsing is one pulse per 1.8 energy units (Wh, VARh or VAh). Kt units are measured in Watt-Hours.
Charles_Murison
Champion
Hello @SESA528 ,
Charles
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-16 09:09 AM
Hi @Charles_Murison ,
Yes. Thanks very much
SESA528
SESA528 Contributor
Contributor
Posted: ‎2022-03-16 09:10 AM
Hi @Bojan ,
Thanks very much
